CompactRIO 9040 Modbus Communication on Embedded RS485 Port
Updated Mar 26, 2018
  • cRIO-9040
  • LabVIEW Real-Time Module
Other
Modbus
The CompactRIO 9040 Controller has an embedded RS485 port. Can I use this embedded port for Modbus communications?
The RS485 embedded port on the CompactRIO 9040 Controller is enabled for Modbus communications using the LabVIEW Real-Time module.
