CompactRIO 9040 RS485 Maximum Baud Rate and Cable
Updated Mar 26, 2018
  • cRIO-9040
What is the maximum baud rate supported by the RS485 port on the CompactRIO 9040 Controller and what type of cable can I use?
The maximum baud rate is specified in the CompactRIO 9040 Controller Manual, which is 230,400 b/s. The recommended cable for the RS485 port is specified in the CompactRIO Serial Cable Accessories document linked below.
