I Can Not See the Vision VIs in LabVIEW
Updated Mar 26, 2018
  • Vision Development Module
  • LabWindows/CVI
I have installed the Vision Development Software in my computer, but I can't see the vision palettes in LabVIEW, why is this the case and what do to add the vision tools to LabVIEW.
This would happen if you are using a version of LabVIEW and the Vision software that are not compatible, to see if this is the case you can reference LabVIEW, LabWindows/CVI and Vision Development Module compatibility
If the software versions are not compatble you'll not be able to use the Vision tools in LabVIEW.
If the software versions are compatible it is possible that there was an unexpected error during the software installation process that resulted in this error, if this is the case you can try Uninstalling or Repairing the NI Software.
