Resistor Value of NI 9208
Updated Apr 17, 2018
  • NI-9208
I'm used to using shunt resistors in my application. On the data sheet, I see that there is what appears to be a shunt resistor in the NI 9208. What is the value of the resistor?
The 9208 uses a series of resistances. However, the value that would be the equivalent of a shunt resistor in this module is the input impedance. This value is 85 Ohms.
