DAQ Assistant Stuck at 'Initializing...' When Placed Onto Block Diagram
Updated Nov 25, 2020
When I place a DAQ Assistant block onto the block diagram it won't initialize, causing LabVIEW to freeze. How do I fix this?
Please try the following following troubleshooting steps:
Reinstalling NI MAX will prompt you to reinstall any dependent software, such as LabVIEW.
If the above steps do not work then please contact NI Support for further assistance.
