Creating DAQmx Task in NI MAX Uses Development License in VLM
Updated May 25, 2018
I am a client that use a network license through VLM.
When I create a DAQmx task in MAX, I see in License Manager that a Developing Network License is in used,
Once I close MAX, the License is not in used anymore
You have to disconnect the client computer from the license server when you are configuring DAQ tasks in MAX.
Following, a licensing policy is described:
  1. Creating a task in NI-MAX uses the DAQ Assistant
  2. The DAQ Assistant is licensed through your development environment (LabVIEW, LabWindows/CVI, etc)
  • If the DAQ Assistant has a license available to use, it will use that license rather than run unlicensed
  • If there is no license available to the DAQ Assistant, it will give a warning but still run
