Logging TestStand Login Information For Each Socket
Updated Apr 2, 2018
  • TestStand
I am working with a system that has 1 host machine and several testing machines to test each device due to hardware limitations. I want for each user to login and have TestStand store that information for each device under test. I see there is this functionality using the front end callbacks in TestStand to login initially into TestStand itself, how can I modify this to work for each socket?
There is not a direct way to achieve this functionality however, some architectural options for this are
  • Designing a model plug-in and writing code modules that has the login screen pop
  • Created a step with code modules that has the login screen pop
