Smart Camera Digital Output Does Not Persist After VBAI Inspection
Updated Apr 18, 2018
  • Smart Camera
  • Vision Builder for Automated Inspection
I want to output a digital high from my smart camera at the end of my VBAI inspection and for that output to continue when I start the next inspection. When my inspection finishes, the output goes low. Is this expected behavior?
When VBAI unloads an inspection the digital lines are pulled to their default value, which is low. This is expected behavior.
In inspection interface mode, VBAI does not unload the inspection when you click on the stop button. In this mode, the digital line should remain however it was configured, even if the inspection is stopped.
In configuration mode, VBAI unloads the inspection when the stop button is pressed. In this mode, the digital line should default to low when the inspection is stopped.
