Performing External Calibration without LabVIEW
Updated Apr 18, 2018
  • PXIe-4353
  • CAL-4353
I want to perform external calibration on my SC Express card, but I don't have LabVIEW. Is there any way to perform the calibration? Can I do this using NI MAX instead?
Because external calibration makes calls to the NI-DAQmx, you will have to have access to this driver. This is most easily done in LabVIEW, but can also be done in any C programming environment that can access the NI-DAQmx API.
