To use the FTDI USB devices with LabVIEW, you will need to download and install the Virtual COM Port Driver from the
FDTI Chip VCP Driver Website for your specific operating system.
Make sure you have NI-VISA installed. You can verify this within NI MAX by expanding the software tree to see if NI-VISA is listed towards the bottom. If you do not see the NI-VISA driver there, you can download and install the NI-VISA driver from National Instruments VISA Driver Download Page.
Once you have this installed, you should see the device within NI MAX under My System»Devices and Interfaces»Serial & Parallel»"Your Device" (ComPort).
To communicate to it in LabVIEW you will need to configure the Serial port with the right baud rate and use the VIs supplied with NI-VISA.
