Error 0 When Adding Tables to MySQL Database From TestStand
Updated Apr 6, 2018
  • TestStand
  • TestStand 2016 SP1
I have set up a MySQL database to use with TestStand. I tried to add the default tables required by TestStand in that database but I keep getting "Error 0: Data source name not found and no default driver specified". Why is this happening and how can I fix it?
This issue is caused by an incorrect Connection String Expression in the TestStand Database Options windows. To resolve this, use the correct syntax for the connection string that you can find inĀ Configuring Connection Strings.
