Minimum Sample Rate of NI-DAQ™mx Devices When Unspecified
Updated Jul 8, 2026
  • NI-9205
  • NI-9201
The datasheet for my NI-DAQ™mx device does not specify a minimum sample rate. I've seen other NI DAQ devices that specify a minimum sample rate. Does this device have a minimum sample rate if it isn't included in the data sheet?
Some NI-DAQ™mx modules that use Delta-Sigma ADCs require a minimum sample rate because they oversample signals for filtering needs. If there is no minimum sample rate specified, your device can sample as slow as your time base allows.
Note: For any sampling at frequencies less than ~1 Hz, software timing is an appropriate alternative. See Accuracy of Software-Timed Applications in LabVIEW for more information on software timing data acquisition.
