Missing NI System Driver Set When Building Installer
Updated May 3, 2018
I am getting an error that I am missing the NI System Driver Set when I try to build an installer. How can I resolve this?
You will need to download and install the NI System Driver Set installer from the System Driver Sets web page.
The error message should give you the release date of the driver. If it doesn't, then click on the driver that you think might be correct from the link above. It will take you to a new page that will give you specific details of the software versions that are included in the driver. Choose one that is compatible with you system.
