Can't Discover Modules in 9151 Using R Series Card
Updated Nov 30, 2018
  • PXI-7851
  • PXI-7854
  • NI-9151
I've tried connect my R series card to a 9151, but my computer won't recognize the modules in the 9151.  What could be causing this?
There is a chance that a fuse has been tripped.  We can check this by:
  1. Plugging the R series card into a breakout board, such as the SCB 68.
  2. Measuring the voltage between the +5V and ground pin.
If the voltage is +5V, the fuse is not tripped.  If the voltage is 0, then the fuse has tripped.
If you are using a NI 784xR or NI 785xR, you can manually replace the fuse as shown on page 2-29 of the NI R Series Intelligent DAQ User Manual
Newer versions of the NI 781xR and 783xR must be returned for repair, while older versions have a self-restting fuse.
