BNC Breakout for PXIe 4339
Updated Apr 16, 2018
  • PXIe-4339
I need to breakout my signals outputted by my PXIe 4339 into the BNC form factor. Is this possible?
In order to breakout the PXIe 4339 pins into BNC terminals you will need two peices of equipment. First you will need the SH-96-96-2 cable which plugs directly into the PXIe 4339. Lastly you will need the RM-4339 terminal block which breaks the SH-96-96-2 cable pins out to BNC.
