Is Termination Resistor Needed With USB-8476S LIN Interface Device?
Updated May 7, 2025
  • USB-8476
  • USB-8476S
  • NI-CAN
I am using USB-8476S LIN Interface device.
Do I need to connect a termination resistance?
The LIN master node requires a 1 KΩ resistor and serial diode between the LIN bus and VBat.
On NI USB-LIN products, master termination is software selectable, thus you don't have to connect an external termination resistor to USB-8476S if you enable the Termination attribute .
This attribute can be enable using ncSetAttribute function within the NI-CAN Frame API.
If you are using LabVIEW, you should call ncSetAttr.vi to set Termination attribute to 1 as displayed below:
If you are programming in C, you should call ncSetAttribute to set Termination attribute to 1 in order to enable termination.
LIN cables require no termination, as nodes are terminated at the transceiver. Slave nodes are typically pulled up from the LIN bus to VBat with a 30 KΩ resistance and a serial diode. This termination is usually integrated into the transceiver package.
What is described in the Solution above also applies to USB-8476.
