How Do I View All of My Cluster Elements?
Updated May 4, 2018
I have a cluster with numerous elements, but I can only see some of them. How can I view all of the elements in the cluster?
How a cluster indicator or control appears on the front panel is defined by the AutoSizing selection when you right-click on the cluster. The None option allows for some of the cluster elements to not be visible. Selecting any of the other available options will cause all of the cluster elements to always be visible.
The Size to Fit option lets you rearrange the elements as you wish, with the overall indicator or control sizing to fit all of the elements. The Arrange Vertically and Arrange Horizontally options both arrange all of the elements in the desired orientation as close as possible, and don't allow you to move the cluster elements.
