When I Install NI VISA Does It Also Install the NI 488.2 Driver
Updated Dec 7, 2022
  • GPIB Cable
  • NI-488.2
  • NI-VISA
I'm using a GPIB device, and installed NI VISA, but I am seeing the following error/message:
Error: Windows does not have a driver associated with your device
I made the assumption that when I install NI VISA it would install the 488.2 driver as well. Was I wrong and what is the latest version of it that I should use?
Anytime you are working with GPIB devices, you need to have both the NI VISA and 488.2 drivers installed. It is important to install both of these drivers before adding new GPIB devices so that Windows can recognize them.
