This message is most common if LabVIEW cannot allocate a block of memory large enough for an array. For example, a 2D array of double-precision floating-point numbers of size 2,000 by 2,000 elements uses approximately 32 MB. Even if 32 MB of memory is available, you may not have a block of contiguous memory large enough for the array.
This message is also generated when an array containing more than 2^31 elements is used to index a For Loop. Arrays can contain up to 2^32 elements, but a For Loop can only index up to 2^31 values. This is because the N terminal uses the signed 32-bit integer (I32) numeric data type rather than the unsigned 32-bit integer (U32) data type. The most significant bit of the I32 data type is used to specify whether the value is positive or negative. To get around this limitation, you can split your array into two smaller arrays, or replace your For Loop with a While Loop, comparing the iteration value to the size of the array and terminating when the two are equal.
To add, this message also can be associated with the Windows OS issue which is unable to provide the necessary resource memory for the LabVIEW application. Try to test the code with a fresh NI installed software in a fresh Windows PC to try to resolve the issue.
