Error -89130: Device is Not Available for Routing
Updated Jul 31, 2023
When I attempt to acquire data with my NI Multifunction I/O (MIO) module, I  receive the following error message:
Error -89130: Device is not available for routing. It is possible that the device needs to be reset or that the device is being reset.
If you encounter this error, please try the following steps:
  1. Review this article if you are communicating with a DAQ device on a real-time (RT) target.
  2. Reset the device in Measurement & Automation Explorer (MAX).
    1. Open MAX and find your device under Devices and Interfaces.
    2. Right-click your device and select Reset Device.
    3. If you get Error -88705, check the status of NI Device Loader. The reset can be executed programmatically using the DAQmx Reset Device (VI).
  3. Reset the MAX configuration data. If the reset fails, try to reinstall the device:
    1. Remove the device from the Windows Device Manager. (You can access the Device Manager by right-clicking My Computer and selecting Properties.
    2. Click the Hardware tab and select Device Manager.
    3. Find your device by expanding the Data Acquisition folder.
    4. Uninstall your device by right-clicking and selecting Uninstall.  (Follow the prompts to uninstall your device.)
    5. Windows should automatically detect the device and allow the Add New Hardware Wizard to automatically choose the driver for your hardware. If your device is not detected initially, restart your computer.
      • In Window XP, navigate to your Control Panel and select Add Hardware. In Windows 7, select Add a Device in your Control Panel.
    6. After a successful reinstall, try self-testing and using test panels with the device in NI MAX
  4. In case you are routing signals with the DAQmx Connect Terminals (VI) on the backplane make sure that the source and destination terminals are correctly given as well as the trigger source in the device's trigger configuration is selected correctly.
