Can I Choose DAQmx or FPGA Way of Programming for Each Module on CRIO-904x?
Updated Oct 14, 2021
  • cRIO-9043
  • cRIO-9041
  • cRIO-9045
  • LabVIEW 2017 Professional
Can I choose the way of programming DAQmx or FPGA for each module on cRIO-904x?
Yes, you can choose programming mode for each module C series individually:
In order to program the cRIO-904X you do not need to purchase the FPGA module, if all modules are programmed with the NI-DAQmx driver.
